I have searched and searched the net looking for a solution and have found none. Is this not possible? I have even tried exporting the 2D linework to a V8i version drawing and export the shp file, but no luck.
If the coffee corner on 15 March is to be believed, SHP export is coming to ORD in the next release!
I agree. I wish this was as easy as it used to be. Shp files are common!
Finally resolved in ORD 2022 R2:
OpenRoads Designer 2022 Release 2 - Export Elements to Shape File - YouTube
Mark
Is it possible to export the metadata from OpenRoads (D&U) as attributes of the shapefile?
Yes D&U attributes can be exported to a shapefile using Flextables. Refer attached photo - hit the export button and the export dialog panel has an option to save as a shapefile.
The benefit of going through a Flextable is you can select which attributes are outputted and control their formatting as well.
Ashwin
