I have searched and searched the net looking for a solution and have found none. Is this not possible? I have even tried exporting the 2D linework to a V8i version drawing and export the shp file, but no luck.
this was a simple task in Inroads SS2, why is Bentley removing capability? Seems like we are going backwards.
I've tried with ORD 10.10.21.004 and the "Export to Shapefile" option is still greyed out. Hopefully the option is coming soon.
Hi Aaron, you will need to create an Asset Manager scheme (using the buttons on the top right) and then it will enable that option.
Mark
can you elaborate on this? i tried to google how to do this and it didn't show any results. what "buttons on the top right" are you talking about?>
Hi Lisa, that was an error - i meant "top left". All you need to do is use Asset Manager to apply any type of data to your elements and then you can use this tool to export to SHP files. A bit convoluted, but a much better and simple export option is coming in the next release apparently very soon.
