Dear All,
i have created Guardrail (with features Guardrail_V2_Single_Sided_L) in Plan but in 3D view & Dynamic Section it is not showing, why?
I am making the assumption that you think that the 3D linestyle- being a combination of "solids"- should show up as a 3D cut whenever the linestyle is cut by a section. OpenRoads does not "see" these linestyles in this manner. In order for you to see the "guardrail", a cell needs to be assigned to the annotation group for the cross sections and needs to be assigned to the dynamic cross section feature referenced. In practice, one would not desire to see the actual linestyle cut, as at different cuts you would see a post, and others just the beam. With a cell defined, one will see the same object no matter where the section is cut.
Mark
