I am trying to create a roundabout using the civil cells. However after going through the process of selecting the primary and secondary alignments, the cell and associated corridor and alignments are generated miles away from the intended location.
Dont know whether its a clitch in the software or if I am doing something wrong. Attached is an image illustrating the problem. I am using version 10.9.0.91
Hello Daniel,
Is it possible to share your dataset with us to reproduce the issue?
You can upload it here: https://bentley.sharefile.com/r-r41250d98eae54c45a76b1482dc8f079b
Please name the folder related to your query, so that it makes it easy to identify.
www.youtube.com/watch
Are the units the same in your working DGN and the DGNLIB the cells are coming from i.e. both metric (or imperial)?
Hi Kiran
I have uploaded the files as requested.
Yes..everything is in metric format. I have already shared the files with Kiran. I could share with you also of desired. thanks
hi. İ have the same problem. Could you solve the problem?
