Hi, I'm having trouble getting an output with end area volumes report. I'm comparing two terrain surfaces rather than a corridor but can't see that would be a problem, the cut/fill mesh looks fine. I'm working in the following sequence and can see that an XML section is added to the named boundary properties.
I even get a correct read out on the Volume.xls report - This would actually be sufficient but I want to place an EAV annotation on my drawing XS sheets and that takes values from the EAV report
See the following video on the Civil TSG youtube channel - it may be what you are looking for.
https://www.youtube.com/watch?v=PiFB4e-HKGw
