I need to cut some portions from mesh and make them solid for calculate volume. I am trying with mesh subtract but not getting it.
Please help me to resolve my issue.
Thanks & Regards,
Gaurang Raval
If I am understanding correctly, your issue sounds similar to the one from this forum post. Check it out and see if any of the suggestions help.Regards,Jacob
Answer Verified By: GAURANG RAVAL
Hi Jacob
Actually my issue is different, I want to cut mesh portion of backfill where my structure(Bridge/Culvert) is placed. after cutting the mesh I need to make the mesh in solid.
Hi Gaurang,
You can create Plan Named Boundaries that do not include the bridge and calculate using the Quantities by Named Boundary command, or alternatively use a different Template Drop where the bridge is that has Volume set to "None".
You should never need to manipulate the ORD Meshes to change things like Volumes, etc.
Mark
I want to construct a mesh element by subtracting one existing mesh element from another.
I already tried to subtract with using the other element in with mesh and more solid forms.
Please advise.
