Reference is in another coordinate system
Hallo
I’m working on a project that’s in a coordinate system (UTM32) but for the project I need to reference another project in which is in another coordinate system (DKM2), how can I do so they are in the same coordinate system or are in the right place according to each other.
My project is a road in rural area that is sectioned and drawn by different companies that is why the reference fil is not in the same coordinate system.
I hope someone can help my :-)
  • First you will need to make sure that each of the dgn files has the correct Geographic coordinate system attached. You will find those tools under Drawing > Utilities > Geographic.
    After they both have the correct coordinate systems defined, you then can attach one as a reference to the other. When both the active file and attachment have a defined GCS, the Geographic orientation options are available. Choose the Reprojected option. Your reference attachment will be transformed to fit the GCS of the active file.
    Rod Wing
    Senior Systems Analyst
    Answer Verified By: Sarah Provstgaard
Reply
    Rod Wing
