Sheet Index
I am trying to create Plan/Profile sheets in ORD and It seems to me that my Sheet index within explorer isn't functioning properly.  Once I create the said named boundaries, I try to drag the models into my sheet index to edit but nothing happens.
I also noticed that I'm missing quite a few Icons within the sheet index and I'm assuming this has something to do with it not functioning properly:
I have right clicked over the icons and selected "show all" but it shows that all of the available Icons are showing within this workspace.
Could I get a little direction on how to go about this issue?
Andrew
Parents Reply
  • Yes it can contain the custom/advanced WorkSet properties. When you create a new WorkSet from a Template WorkSet all of the properties are in the new WorkSet.
    I haven't tested recently, but in the past using the method I described above (remove the dgnws, set the template variable, and automatically create a new dgnws) only the Sheet Index settings and folders would be in the new dgnws, the custom WorkSet properties would not be there.
    Rod Wing
    Senior Systems Analyst
