Cant open SS4 file
I have a ditch file I cannot open.
the circle keeps spinning. Please help!
Are there any ideas why this might be happening? Thank you.
Parents Reply
  • You can attach it here; if not as a DGN, you can add it to a ZIP file and attach it to your message.
    If you can attach it to a blank file and reference it in, you may be able to copy everything over into that blank file and use that as your new master. I forget how robust SS4 is about copying over civil data, but I think that might work.
    MaryB
    Power GeoPak 08.11.09.918
    Power InRoads 08.11.09.918
    OpenRoads Designer 2021 R2
