Greetings,
I'm using ORD 2020R3. I have geometry I'd like to export to an InRoads ALG. I thought the command "Export to Native" is what would be used. But I cannot find it anywhere.
Was this command removed? Is the standard workflow now to export to LandXML first, and then import that XML into InRoads SS2?
Can someone point me to what I may be (and likely am) missing?
Hi jcallicott
You're right, the ALG option is not included among the export types available in the Geometry > General Tools > Import/Export > Export Geometry, even though it's still listed as an option in the help page for this command:
https://docs.bentley.com/LiveContent/web/OpenRoads%20Designer%20CONNECT-v11/en/GUID-32329C98-C086-47A4-A4DC-884625C21655.html
Please use the LandXML workaround instead.
Answer Verified By: jcallicott
Grzegorz can you log an enhancement request to get export to alg and export to ird reinstated. These are needed to be able to rebuild our models, following critical failures in the dgn.
Chris
AECOM Roads UK&I Digital Engineering, Design & Solutions Lead | Sector Information Management Lead
Associate Director – Digital
OpenRoads Designer 10.12 | MicroStation 2023 | ProjectWise CE 10.3.4 | ContextCapture | ProjectWise PowerShell 2023 | ProjectWise WSG API | Generative Components | OpenBridge Designer 10.12
Civil 3D 2023 | Dynamo | Navisworks Manage
PowerShell | Visual Studio | Office 365 | Power Platform | Teams | SharePoint | Visio
Speckle | BIMVision | Revizto | Solibri
