I have my proposed corridor which includes the interstate, ramps, and a grade separated road below the interstate. When I cut my cross-sections there are sections that I would like to have matchlines as it does not make sense to show the entire length of the cross-section. How do I go about doing this at a multitude of locations?
You can set multiple named boundaries along the alignment, in the same group, but with different settings (left/right offset).
Another way could be to use a DGN for Xsections (usual workflow), reference all required models in the 3D model, and clip references to keep only what you want to see
Answer Verified By: Yash Patel
Ah yes you're right that latter method is currently what I am doing and I should just be able to turn off the references that I don't want to show up. Thanks.
