We’re trying to label our cross sections, and we are using a preset annotation group. For some reason we cannot get the tie in slopes to display. We tried using the “create list of segments tool” and that doesn’t seem to work right either. When I apply expressions when using the create a list then all the slopes get deleted. So, trying to stick with the “use all segments tool” in the segments to be filtered tab. Any suggestion or idea why our tie in slopes won’t annotate? Also proposed elevations are not showing up either.
Does anyone else have any suggestions? The wiki link below didn't help unfortunately. I also brought over templates from ss10, if that could potentially be the issue. If so is there a fix?
Have you tried adding in a fake segment from a template and renaming the strings ( caps lock sensitive)
