Corridor Projected onto Profile
Is there a way to project a corridor onto a profile created in Geopak, via the Draw Profiles?  Working with someone else who is manipulating the corridor and we do not have the rights in PowerGeopak to edit the file.
PowerGeoapk SS4 v08.11.09.878
  • Your cleanest path to this is probably to create a Terrain Model from the Corridor and export that to LandXML for import into GEOPAK. That surface can them be sampled with your legacy GEOPAK tools.
    Hope that helps.
    Steve
    Steven Litzau, P.E. - Senior Consultant
    www.envisioncad.com
    ORD - 10.12.02.04 / 10.10.21.04 / 10.10.01.03 / 10.08.01.33
    Power GEOPAK / Power InRoads - 08.11.09.918
    Civil 3D - 2021 / 2022
  • Steven, thank you for the reply.  We have been told to wait on the tin file, but complete the work for a 60% submittal.  Which leads me to a follow up question(s).  Since I’m more familiar with Civil 3D let me ask based on my knowledge there and hopefully someone can point me to something similar with PowerGeoapk SS4.  Part of the answer to my question seems to be in the Subsurface Utility, I need to research this more.  In Civil 3D I’m able to dynamically link structures to surfaces and/or corridors, so as the surface and/or corridor change so do the structure tops.  Structures can graphically be drag around in Civil 3D and the pipes following (are linked to the structure).  Profiles with the structures and pipes dynamically change with updates.  So my questions are these 1) Will the Subsurface Utility accomplish the same things?  2) Can a profile for the storm sewers be created based on the corridor that is dynamically linked? 3) If this can be done any suggestions to find training material online?
