The Corridor created does not match with horizontal alignment that had the same starting and ending point. there is any solution to this problem?
May be you have not selected corridor baseline properly.
how can I know baseline not selected correctly
Hover over Corridor line and you can see Plan & Profile Name.
Or you can select corridor & select properties to see your alignment & profile.
As shown below alignment not included in the information of corridor, any suggestion
That is not corridor details, It is a line string details.
thank you for your helping i found a problem in dgn file that overwting some files.
