Im working with the CDOT workspace for Openroads CONNECT edition and I am importing the survey field data. When i do all the line work comes in on the default level. Where can i find the field codes in Openroads to find out why it is not recognizing my field codes? I am using a PNEZCD Point Northing Easting Elevation Code Description TIW and i am importing a .csv. CDOT uses a field code system with a 4 digit number for each code. For example top of curb is 3506. then after the period we use the line number to identify lines and then we use the standard ORD linking codes for start curve etc. All the linking codes are working, the line work is being drawn, the points are being found, but all the line work is going onto the default layer. Under the line properties it says feature definition not found. Then under explorer/openroads standards/ feature definitons/ survey. I added a new feature definition called Linear and under symbology/linear feature symbology i selected a random linear feature symbology and redrew my linework and it worked..... i have no idea what is going on here. Can anyone explain why ORD could not find the feature definitions until i added an empty feature definition and then selected a arbitrary linear feature symbology?
Thanks for the input Bob. If running simultaneous strings with the same code, i.e 1310.01 and 1310.02,, when the connect codes are removed, how does ORD handle this with stripping out the connect codes?
Thanks.
