I have a couple of quick questions regarding cross section annotation groups and the use of dimensions.
1. As you can see the dimensions have open arrows. Is there any way to make these arrows closed? The element template references a dimensions style with closed arrows but this does not carry across into the markup.
2. On the left you can see 3 different annotation definitions for the three dimensions. I attempted to combine them into one, but when multiple segments were selected they all disappeared. Is this a common issue?
Good afternoon.I realize this is an old post but I was wondering it you got this issue resolved. I've been asked to fill the arrows in the annotations and haven't found a way to do it yet.
On the chance someone finds this post in the search for the answer, the solution is to add a fill type setting to the Element Template used for the dimension. In the above example this would require modifying the "Annotation/Arrow" element template.Here's a post I made where the solution is shown.
Thanks so much for the update Matthew - admittedly I gave up when trying to this this previously, so it's good to know there is a solution.
