I have a couple of quick questions regarding cross section annotation groups and the use of dimensions.
1. As you can see the dimensions have open arrows. Is there any way to make these arrows closed? The element template references a dimensions style with closed arrows but this does not carry across into the markup.
2. On the left you can see 3 different annotation definitions for the three dimensions. I attempted to combine them into one, but when multiple segments were selected they all disappeared. Is this a common issue?
Thanks so much for the update Matthew - admittedly I gave up when trying to this this previously, so it's good to know there is a solution.
