Using OpenRoad Designer Connect, How do I import a kmz?
Hi Aaron,
I believe the traditional method to do this is to convert it to SketchUp first and then bring into Microstation/ORD environment. I'm not too sure if the free Sketchup version will let you convert, but worth a try.
How to Import KMZ (Google Earth) elements into MicroStation DGN. - MicroStation Wiki - MicroStation - Bentley Communities
Mark
There is an idea in the ideas section of microstation, for this. You should vote for it.
Frank
@Frank Klein i have no idea what you are talking about. idea section?? what do you mean
I will help you:
microstation.ideas.aha.io/.../MS-I-110
Here's how I import KMZs to ORD / Microstation:
Once you've done it a few times, it takes no time at all.
