I am trying to use OpenRoads to add benching to my roadway model. The goal is to have the model display the benching and also be able to use it for earthwork volumes. The image below is what I am trying to create.
I am still having trouble getting the end condition to work. Have you ever created an end condition for a template like this, and if so would you be willing to share it with me?
I have done templates like this before. I would have to get client permission to share the template with you, and that's a path better not ventured down. Post what you have created and I'll look at it when I have a few spare minutes (looks like Thursday or Friday is currently my first opening and that may change).
Here is the template I currently have. Still having logic issues with seeking existing ground or subbase depending on where the toe of fill is in relation to the shoulder. Any help would be greatly appreciated. Thanks.
benching.itl
This should get you started
2313.benching.itl
This was helpful. I am still having trouble getting the display rules to functioning properly when I try to add extra benches. I have attached the template that I have updated.2781.benching.itl
