I just downloaded the latest CDOT Workspace zip, installed it, & still nothing but "Feature Definition Not Found in Feature Definitions". This applies to ALL linear tmoss codes. The lines connect but all on default. What gives?
Hi James this is a defect in the software. What you need to do is remove the .1's and .2's off your lines and points. I would recommend using the Find/Replace .? with nothing to strip them out. You need to do this for both All Points and All Linear Features in the survey fieldbook.
This workflow is written up in the internal CDOT training guide for Survey Data Reduction. Until the software has corrected this issue it will be part of the normal workflow.
If you have any questions please contact me directly. bob@envisioncad.com
Thanks,Bob Mecham
