Hi
I have a parking lot for renovation vehicles, which is separate in several areas where each area has different type of surface template.
Is there an easy way to calculate material for these areas, or is it the manual method with old fashion calculator easiest.
I am using OpenRoads Designer
regards
Sigfús
I suggest using the Component Quantity tool, where you can select the surface template and you'll get the area and volume with respect to the material.
Avdhoot K.
Answer Verified By: Sigfus Jonsson
