Print Organizer will not print one file correctly. The file prints correctly in PowerGeopak, and all other files print correctly in Print Organizer. I've verified the Properties are correct, and the same as the other files. The issue is spot elevations from the topo are printing even though they are turned off. The Display has Dims, Fill, Level overrides, Line styles, Line weights, Patterns and Text check, all others are uncheck. I'm printing from ProjectWise.
PowerGeopak SS4 v08.11.09.878
Strange question - do you have an active survey book in that file?
On the other hand, I have run into rogue files before where there is some bad bit of data that keeps it from printing correctly (usually showing some element or another that isn't visible any other way). I don't have a good answer to them either. I usually just end up printing it separately to get the job out the door...
MaryB
I'm not that experienced with Microstation and was hoping I had missed something that could quickly be resolved (hoping to learn a new trick). We are at the 60% mark on design and our sheets will be printed as part of a larger set. I have had this happen once before. My solution then was to recreate the file. It didn't take very long so I'll try that again.
As far as the survey book, it is not in this file but a referenced file.
If that survey book file is referenced into other sheets without an issue, then that isn't the problem. But if it is unique to the troublesome file, it might be worth seeing what happens if you detach it.
Yeah, I've had to recreate files before and it usually works. there may be more to it, but sometimes I just need to get on with the work.
