Hi Bently communities.
I have drawn a roundabout, and as I was trying to extend some lines, my ORD froze, and then this message came up, what can I do to save my file, because I can't open it?
Would you attach the file here to see if there's anything we can do to recover it?
https://bentley.sharefile.com/r-r1f0cff7203a343bb9e18c09bf02a0d44
For more information about the Road and Site design tools, visit the Road and Site design WIKI at:
http://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki
Hi Marcus.
Is there any other way to opload my file.
Because every time I try to opload the file, this message pops up.
You might try attaching it directly on this page by going to insert>Insert imag/video/file
or trying with this link instead: https://bentley.sharefile.com/r-r5318677bb2d44a8fb3cff328f559c1d6
I found a solution, and recovered my file, but anyways thanks for the help. :D
Would you mind sharing the solution so that other may benefit if they encounter the same problem?
Yes of course, I found out that I had saved it at my one drive, and that I had the old backup file, of course some of my drawings was lost but I left clicked on the file and when for properties and then pressed older version and suddenly it work.
