I am adding a set of utilities into a model relative to a Terrain Model and all is going well, except that I don't know how to modify the distance between generated points on the resulting conduit.
The black line is the Terrain Model, the green line is the duct.
How do I set the interval between gradient changes on the duct so they are less than 10m (which seems to be the default).
Rob Howe
Hello, I'm resurrecting this one with a follow up message. If, after changing the Feature Definition of Single Gradient to False, can you reprocess an existing conduit to maintain a parallel offset? Or does the conduit need to be deleted and replaced?
