[ORD] Asset Manager export to Shape file?
Hi all,
Does anyone know of any info about the process to export to a Shape file using ORDs Asset Manager?
Does it only include elements included in the selection for the current Asset Manager application?
Mark
  • I just discovered this fonctionnality when you mentionned it in a previous post (last week I think)  I have been trying it a little bit, To export with this tools you first need to associate Item Type trough the Asset manager then you can export your line and shapes.  Since it's not something that I'm gona use a lot I just created some basic assets for Line lenght, surface area, volume and element volume.  But the data is well read for Bentley and Autodesk.
