Centerline vertical geometry not displaying in 3D
I'm using Power Geopak V8i SS10. Very new user.
I have my centerline horizontal and vertical created and both have been exported to the gpk. My geometry file is referenced into my model file. When in my model dwg, if I switch to 3D space, the centerline does not show up. Also when selecting my centerline, it does not give me the option to open profile view. Any ideas?
All help is appreciated, thank you!
  • I may try to just remake the alignment and see if it recreates the 3D geometry, it shouldn't take me too long to recreate. Maybe my horizontal alignment is corrupt for some reason or something. If that doesn't resolve the issue I might attach a file here and/or file a service ticket with Bentley Support.
    Thanks for all your help!
  • (I replied here once, but then had a note that I was "offline", so if this duplicates, my apologies.)
    The vertical content that will show in the 3D model is going to be the active profile. Until a profile has been set active, there won't be anything in the 3D model. The opposite isn't always true, in that (depending on which product in the evolution of the tools you are using) clearing an active profile does not always remove the element from the 3D model.
    If the profile has been set active, and you still don't see it, I would start to check levels and the Feature Definition to make sure something is defined for the 3D representation.
    Steve
    Steven Litzau, P.E. - Senior Consultant
    www.envisioncad.com
    ORD - 10.12.02.04 / 10.10.21.04 / 10.10.01.03 / 10.08.01.33
    Power GEOPAK / Power InRoads - 08.11.09.918
    Civil 3D - 2021 / 2022
    Answer Verified By: Kevin Bogert
  • That worked! I set the profile as active and it now displays in the the 3D view. Does that mean when creating vertical alignments for other horizontal objects (edge of pavement, top back of curb etc.) I need to set profile as active every time?
    Thanks so much
