anyone else getting this error when trying to reference a shp file?bentley.orgecplugin ecrepository ref file attachment data conversion
Funny enough, i get this trying to reference in a Shape file created in ORDs Asset Manager (but works fine in ArcGIS)
Mark
OpenRoads Designer 2022 R1 (10.11) | Microstation CE Update 17.2 | ProjectWise CE 3.4
Yeah, I get the same message. All required support files for the .shp file exist in the same directory.
Edit: I found this - communities.bentley.com/.../650377
I got the same error.
My workaround was to directly open the shp file (with MicroStation or OpenRoads), change the cotdinatesystem to be the one I use in my Project and then I saved it as dgn.
Michelle
This was the only thing that worked for me. Thank you
