Hello
I have a question regarding the corridor. I have tried to find the answer, but I can’t, so maybe you can help.
The question is if it is possible to make a diagonal cut in the corridor and if so, how?
The diagonal cut is going to be the big black line in the yellow shape, in the photo down below.
This discussion should help: https://communities.bentley.com/products/road___site_design/f/geopak-inroads-mx-openroads-forum/178764/skewed-cross-sections-in-openroads-designer
MaryB
Unfortunately not, I’m not looking to make a drawing but to connect 2 different corridors in a diagonal. Sorry I did not make that clear in my question :-)
Hi Sarah, create a closed shape at the end of the corridor that you want to cut and add as a Corridor Clipping element to your corridor.
Please note that clipping will only be applied to your 3d model, but thats all you should need.
Mark
Answer Verified By: Sarah Provstgaard
Thank you, this was very helpful :-)
Hi Sarah,Does that work, if yes can you drop some steps for it ?
