suppose I have 2 elements at the same location in my dgn file. Perhaps one represents the centerline alignment and the other represents a 2D pavement crown along the alignment with zero offset. When I use the Place Label tool to label the 2D pavement crown, the centerline alignment gets selected. When I right click to try to choose the 2D pavement crown instead, the command cancels. sure, I can turn off the alignment level to pick the pavement crown line, but this seems like this extra step shouldn't be necessary. I'm hoping this is either a defect or I just haven't learned the magic keystroke to cycle through elements when using the Place Label tool yet.
This may be related, it may not: https://communities.bentley.com/products/road___site_design/f/geopak-inroads-mx-openroads-forum/213822/ord-cycle-through-elements-with-civil-accudraw-active
Is your Civil Accudraw active? Perhaps you can switch to regular accudraw.It is also possible that this is actually a problem with the program. You can always file a service ticket with support, and come back to us with whatever answer they can give you.
MaryB
the tentative snap did the trick! thanks!
You're welcome!
