When will ve available Dark Theme for all applications built on Microstation CE such OpenRoads, OpenBridge, OpenRail, OpenBuildings....?
Hi Manuel,
as far as I know it should be available in next ORD release, but let my colleagues confirm it. I am not sure about other products.
I do hope that more energy is going into fixing "defects" and regressions than into mere cosmetics...
MaryB
Answer Verified By: Manuel Soriano
YUP
Robert Garrett Senior Consultant
www.envisioncad.com
Well Mary, everything is important, Dark Theme is not a cosmetic feature only, I work on my computer at least 10 hour a day and I have a diagnosis of glaucoma, for which the white backgrounds aggravate the disease and can lead to blindness, as you can see, it is not just a cosmetic issue.
My apologies. I did not understand that this was indeed an issue for you. I'm very sorry for my assumption.
