In bentley V8i based prodcuts the Datagroup explorer allows you to export data vales to excel and then imprt them back in.What options do we have for exporting openroads data but the key part is then importing it back in.Ive used microstation connect to export the item data but there is no import options
Are your sure - Item Type Definitions and Instances Export and Import (bentley.com)
This is also included in OpenRoads Designer and all other Microstation CE platform products.
Mark
OpenRoads Designer 2022 R1 (10.11) | Microstation CE Update 17.2 | ProjectWise CE 3.4
Thanks Mark, really appreciated. This worked for Highways elements but not for Drainage feature definitions.
Bentley provided the following article detailing a configuration file variable which unlocks the feature.
https://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki/41067/report-on-feature-definitions-and-symbologies-in-openroads-designer-connect
Will update once i get the chance to test
Drainage elements data can be exported using Item Types but you have to use Expressions to read the SUDA data. However, there is a "simpler" way. Use FlexTables to display the information then export or the Export bottom on Drainage and Utilities home includes Export to Excel.There is also Model Builder for importing and exporting data for Suda. It syncs the data in Suda with a series of data formats.
I personally prefer Item Types as the data fields can be customised and you can have a variety of Automated and manually populated fields.
Chris
AECOM Roads UK&I Digital Engineering, Design & Solutions Lead | Sector Information Management Lead
Associate Director – Digital
OpenRoads Designer 10.11 | MicroStation CE 10.17 | ProjectWise CE 3.4 | ContextCapture | ProjectWise PowerShell 2.0 | Generative Components | OpenBridge Designer 10.11
Revit 2022 | Civil 3D 2022 | Recap 2022 | Infraworks 2022 | Dynamo | Navisworks Manage
PowerShell | Visual Studio | Office 365 | Power Automate | Teams | SharePoint | Visio
Speckle | BIMVision | Revizto | Solibri
thanks Chris, the data is taken from Microdrainage, the model builder is used to generate the 3D elements which are Feature definitions defined by Node. The discipline does use flextable to manage the data handily but the issue from my side is that the flex tables allow export but there is no import ability i could see.
Using the Data externally allows us to pick up the Element ID and the GUID for each "asset" which we are using to form a manual input into the asset management system. The asset system then generates an asset specific UAID which we want to enter into the already existing custom datafield present with the schema just seems strange to be able to export from a flextable but have no import ability.
Are you wanting to add additional data or change the data in the flextables?
