Survey not Processing on Open Roads Disaster
I have an issue where my files stop recognizing the new survey point that I import.
The issue is some times will bring in the points but I will not create the linework, I can't create the linework since changing the link code does nothing.  Also, I have had this happen more than once where certain codes are not recognized so the points will not come in all together no error shown since the codes are valid codes just not processed. none of the times is the surface updated or created.
I have spent three days trying to troubleshoot this issue to no avail. Does anyone have similar problems that they have been able to fix?
I have tried recreating the drawing with a clean seed file, which worked for a while, and then it stopped altogether so I am back to the beginning. any help would be nice. I have made sure the feature definitions are all set up correctly.
