Dear All,I cant establish an interchange ramp connection between elevated viaduct and at-grade sections. I have attached a screenshot of the area that need to be interchanged. Also attached the working file in the link below for your reference.Appreciate if anyone could guide me on this matter. Thanks in advance.
Folder Path: 1drv.ms/.../s!Atg_UdzhTl5cnN989yubVVJJdRoGoA
What software are you using? And version?
A random picture of somewhere is not helpful, and personally I would be wary of clicking on an unknown link.
Sorry for giving you the folder path in the link format. The file size is huge and i cant uploaded here. So i have uploaded the files into my onedrive and shared the link. The design is based on openroads concepstation software. Its the latest version ( cant remeber exactly right now).
While I can't speak directly to conceptstation, general design procedure would probably be to design the at grade road, the elevated road, and then the ramp, using the other two as surface/design references. Which part isn't working for you?
MaryB
Hi Mary,
That's the usual way of designing a ramp connection between two sections. However, in my situation, the ramp is needed to be connected from at-grade (existing road) to an elevated viaduct which doesn't have any at grade section ( I mean no abutment). Its just fully elevated. I dont see any template available to do the connection between these two sections.
I can see your problem. How are you designing this viaduct? Would it be possible to create a "working" corridor where this structure is, to assist with your ramp design? Hopefully someone with a more thorough understanding of all the design options will be along to offer a more creative and effective solution.
