Hi all,
I am hoping to create some Place Label shortcuts but there seems to be an issue with them in ORD 2020 R3. If I run the keyin:
placelabel dialog;placelabel cellname "_Lbl_Pln_AlignName-Sta-Off"
it successfully opens and edits the values in the dialof box, however, it skips the option to select an alignment to Label and goes straight to the point, which has empty values.
The "placelabel tool open" keyin opens the "normal" Place Label tool and works fine, but none of the keyins affect the dialog.
Has anyone had some luck with this?
Mark
"doccenter place label" command removed and replaced with "placelabel dialog" between 2020 R2 and R3? and broken?
Setting a Text Favorite Name for Place Label by keyin? - OpenRoads | OpenSite Forum - OpenRoads | OpenSite - Bentley Communities
Mark:
I am using 2020R3.
I believe that what you are attempting to do is what I have contained in the following script (which I have set up as a custom menu set for Rights-of-Way labeling). This one places a Station/ Offset label for Rights-of-Way located on the left side of an alignment:
"Template Active Annotation\Sheets\Plan\Right-of-Way\Prop. ROW\Offset Plus and Distance; ac=_Lbl_PR_Pln_Sta_Partial_Lt; Active Style= 0; dimstyle active= _Lbl_Pln_Sta_Partial; Placelabel Tool Open"
It prompts me to select the alignment, and then allows me to place the label with the correct station and offset based upon that alignment.
Answer Verified By: Mark Shamoun
Hi Mark,
nice - so use element templates to set the cell and run the the tool. That should do what I need (ill put a ticket in for the the placelabel dialog function)
Glad to help. Yeah, I have created custom dropdowns- for our firm- for all of these sorts of manual labeling procedures. A bit antiquated, but I am an antique of sorts, LOL. Thanks for putting in a ticket!
Mark Plum said:"Template Active Annotation\Sheets\Plan\Right-of-Way\Prop. ROW\Offset Plus and Distance; ac=_Lbl_PR_Pln_Sta_Partial_Lt; Active Style= 0; dimstyle active= _Lbl_Pln_Sta_Partial; Placelabel Tool Open"
Sorry if I am hijackings your thread, but this is some follow-up questions to Mark Plums' reply:
If you had an element template that also included the cell and the dimstyle, could this be boiled down to setting the active template and keying in the Placelabel Tool Open command?
And are these accessed within your ribbon via a customization or some other GUI item?
