ORD - R3 - Geometry Builder breaking relationships between Centerline and Edge of Pavements
I used the “Geometry Builder Edit” tool to edit a construction centerline and it resulted in the relationships between the centerline and EOP lines being broken. Is there a different way to edit complex centerline geometry without breaking relationships between other elements?  We can provide the file in question if need be.
