I'm working on a utility model that is crashing that has over 200 nodes defined. I was wondering if it was possible to
export the nodes out and import them into a new file. I have tried the import/export utilities in Drainage and Utilities without
any success. Are there any better ways to do this? Thanks
Hi John, you can try saving copies of the dgn with parts of your network and then referencing them into a new master file - would that work for you?
