Conduits not showing in plan (default) view but show in explorer - drainage and utilities model
Hi there!
I'm working with ORD Connect Version 10.09.00.91
This is my first project in ORD Connect as well as using the drainage and utilities model.
My problem is that some of my proposed pipes show up in plan view while others do not. All pipes show in conduits under Drainage and Utilities Model in project explorer. I can click on the conduit in explorer and I see the ends light up in plan view but there is no pipe shown. I have created profile runs for all networks and in profile view all of my pipes show up. It's just in plan view that some are missing.
I'm pretty sure I have the newest update but I must be doing something wrong. I had this problem early on when trying to change the name of some structure nodes using utility properties. The nodes would disappear. I've just been inserting new nodes if a name changes. This is taking a lot longer than expected.
Parents Reply Children
