[ORD 2019 R3] Survey Point Rotating to Linear Segments via SmartObjects VBA - Inconsistent Results
We are using a customized version of the SmartObjects VBA Project and it is working as expected for some features but not others. The tool cannot rotate cells upon initial import as the lines are not created until all the points are displayed. So the project requires a manual redraw of the survey fieldbook before the cells will rotate.
We are using it for two types of cells. The ones that work are pavement marking symbols, like turn arrows and word appliques (ONLY, LEFT, SCHOOL, etc.). The only caveat is that sometimes the direction of the nearby lines (road striping) results in the symbol being out by 180 degrees. The ones that are not working are our Guy Wire Anchor Cells. These are usually draw using a JPT code, unlike the road striping. Since that seems to be the only difference between the two, I wonder if the rotate code just cannot work on JPT lines. Of if the fact that the segment shares a coincident point with the cell is the problem.
I welcome any suggestions.
BYW, this is a sort of update to an older thread, but it is a newer version and more information. If anyone has managed to get a Guy Anchor cell to rotate, I would love to find out how.
