Bug in Mirror Command Default Selections
When I use the mirror button from the tools ribbon, it remembers my previous selections of the tool. The default options appear to be whatever was last used. (ie. the "mirror direction" is "line", "horizontal" or "vertical", which ever I last used).
But when I use the mirror shortcut keys (3,5 in my set up), it will always default to "horizontal". It doesn't remember my last settings.
My workflow is mostly the keyboard shortcuts, and since I rarely use the "horizontal" setting, I'm finding it annoying to keep selecting my preferred method.
My colleague at my company is having the same issue, though it doesn't impact her workflow.
Is anyone else observing the same on their system? What's the best way to fix this bug or request this bug be fixed?
Thank you,
Greg
Parents Reply Children
