I am importing a .CSV into my drawing and about 50% of the time, no points will display in my drawing. I can look in the field book and see the points are their with all of the correct information but nothing is displaying in my drawing. I have repeated the process multiple times and i appears to only happen about 50% of the time. Also when i used the NEW POINT tool, the point will be created in my field book, and if i select the point it will center over the correct area but no symbol or decoration will display. This seems to be an error in Openroads. I am working in ORD Release 2 and cannot upgrade to release 3 due to project restrictions and the incompatibility between the two. Is anyone else experiencing problems with survey data imports?
Are there feature definitions and element templates defined for those points?
MaryB
Microstation 08.11.09.919Power GeoPak 08.11.09.918Power InRoads 08.11.09.918
Yes, there are feature definitions and element templates defined for those points. I am using the CDOT workspace. available here (https://www.codot.gov/business/designsupport/cadd/implementation-ord-pw-workspaces)
I can confirm the same issue but have not been able to find a solution.
Sean, are you using the CDOT workspace? If so I found the solution was after import, go to your field book, all point features, right click and select details. Select the field code column and use the replace option to remove all connecting codes from your points and linear features.
And if this doesn't work and cells are still not displaying, I opened the element templates and found the code that was not displaying and determined which cell is was using and opened the CDOT_Survey-Levels_Features_Annotations_Element Temp.dgnlib and made a new cell with the same name and same linework and deleted the cell that was giving me issues. I hope this helps, its been a long time since i had this issue. I guess it has just been working for me now.
I am using an IDOT workspace but I believe I am having a few different issues. Some cells are displaying and some are not. A cell that represents a physical item is displayed (manhole, guy wire, power pole, etc.) along with the decorations but for the cell that represents a shot on a linear item (EOP, EOS, Treeline, etc.) the cell does not display nor the decorations. I appreciate the response. I have filed a ticket with Bentley.
Edit: Actually, Alexander another post from you fixed my issue.
communities.bentley.com/.../in-ord-release-2-after-some-unknown-event-changing-field-codes-in-the-field-book-survey-details-causes-the-point-symbol-to-disappear
