I created the contour from Lidar data using .LAS file. I am facing few issues after created the contour.
1. After created contour the performance of the model is very very slow for small area. If i zoom in it took minimum 2 to 3 minutes to see the contour in the model. for zoom in / out itself took so much time. I am not sure whether i need to check any setting?
2. Then I tried to on "spot elevation" for the same terrain model it is keep on loading for a long time then also i am not able to see spots elevations.
It will be great support if you help on the issue.
Thanks & Regards,
Prema Srinivasan.
I am having different file sizes the minimum file size 5.338 KB and maximum is 732.560 kb. i am using openroad desinger software to create terrain model.
I am using windows 10 configuration. I hope this information will help you.
When you look at the Properties of the terrain, how many points/triangles are there?
I have different volumes of points. my very lowest number of points 91.370 and number of triangles = 182.28
larger number of points 10.681.601 and number triangles 21.356.683.
Answer Verified By: Prema S
is there any update?
