Hi everyone.
I´m using PowerRail track v8 series and I ´ve got a big question in regards to corridor clipping.
I´m not looking for a 2D clip with a closed shape and all the layers/components are clipped vertically but I´ve got a kind of footpath along my corridor which intersects with, it clashes with different components of the template and I´m trying to delete that small part but it has been imposible so far.
I have tried to create a terrain from the cell (the footpath) but is not found for a target aliasing, to use corridor references but nothing, what could be the workflow?
I hope this screenshot explains better the situation
Thank you very much in advance !
Which are you trying to clip - the red shape, or the footpath? Is the footpath a cell, or is it linear elements? IS the other shape a cell, or linear elements?
MaryB
Sorry, I couldn´t answer earlier.
It´s the red shape.
I created auxiliar points in the template in order to be adapted into the point controls drawn along the footpath
You said something about the footpath being a cell? That could be why it is not being recognized as part of a terrain for targeting.
