Can the Civil File Manager included with OpenRoads Designer be used to bulk process or report on files in ProjectWise? If not is their an alternative method for accomplishing this?
OpenRoads Designer 2020 Release 3 Update 9 Version 10.09.00.91
Hi Kevin,
Annoyingly we usually export (with Locking) the DGNs to a local folder, run the utility and import back in. Very messy...
Mark
I was afraid of this. Thanks.
We have it in the backlog: Enhancement 1114034:Civil File Manager ... Enable ProjectWise Integration, and it seems it will be available in the next release.
Answer Verified By: Kevin van Haaren
Excellent as we too are using the workaround that Mark suggested and yes very messy...
Ross
