Update to Vertical Alignment during revision to Horizontal Alignment
In ORD, I have a 10km road alignment, Start Station:0+000, End Station: 10+000
When I tried to revise the Horizontal Alignment between km 4+000 to 5+000, The vertical Profile Levels of the unchanged Horizontal portions also revised automatically.
In Mx , when we revise the horizontal alignment, the vertical alignment elements for the effected portion deleted, we need to revise the vertical alignment, but the vertical profile levels at unchanged portion does not change.
 Actually, Vertical alignment levels, for the unaffected portion of the Horizontal alignment , During Horizontal alignment revision should not have changed in ORD
Request for your kind help in this regard.
Babulal Sahu
