We recently came across an issue, we accidentally detached and re-attached the alignment file and all the labels lost association in open roads designer. Is there a way to re-associate all the labels?
Thank you for your time.
Edit:
I used the Place label tool and placed a label with a text favorite by choosing the alignment. When this alignment file got detached all the text which was associated to this alignment broke. When I move the text around after re attaching the alignment file, it displays the DEFAULT text, used to create the text favorite, in the .dgnlib or .cel file.
You might find the following helpful:
https://www.youtube.com/watch?v=8OplZX2UhLI
Basically if you modify the note it will reassociate to whatever point you like.
Thank you for the reply David. I do know this feature and I understand that it works for Place Note. BUT
I used the Place label tool and placed a label with a text favorite by choosing the alignment. When this alignment file got detached all the text which was associated to this alignment broke. When I move the text around after re attaching the alignment file, it displays the DEFAULT text, used to create the text favorite, in the .dgnlib or .cel file. Actually, I also tried the method in the above video by re-snapping the leader to the alignment but it just displays an ERROR.
I have the same question/issue as Phani, the video you shared does not address the specific issue when a civil label associated with an alignment to give station offset information loses that association, is there a way to re-associate the callout with the alignment so it re-popualtes the station offset information.
Chad,I do not think there is a solution to this issue. I had to delete all the associated labels and redo them.
Phani,
Have you been able to find a solution to this problem of not being able to re-associate Labels? I am finding the same problem with Civil Labeler.
God bless,
David
