We recently came across an issue, we accidentally detached and re-attached the alignment file and all the labels lost association in open roads designer. Is there a way to re-associate all the labels?
Thank you for your time.
Edit:
I used the Place label tool and placed a label with a text favorite by choosing the alignment. When this alignment file got detached all the text which was associated to this alignment broke. When I move the text around after re attaching the alignment file, it displays the DEFAULT text, used to create the text favorite, in the .dgnlib or .cel file.
David,No I have not. Right now the only way is to redo all the labels.
Ok. Thanks. Have you submitted a SR?
I might put in a SR, well now it is a Ticket.
