I turned on my position mapping. I want to use numerical for both "Main" and "Task &Ribbon". I updated my settings accordingly as shown below. (I tried both "1234567890" & "123456789" in the Task & Ribbon")
When I click OK. The settings update and when hover over a tool it shows up properly. As shown below.
I used mu number pad to type the commands. In the example below I pressed 3, the ribbons pops up but when I press 1 it doesn't do anything. I hover over the command it switches to alphabet M and stays like that dis regarding my position mapping settings. How can I address this issues?
By setting both the "Main" and "Task & Ribbon" to use the same key this is causing a conflict.
Phani Gubbala said:I used mu number pad to type the commands. In the example below I pressed 3, the ribbons pops up but when I press 1 it doesn't do anything. I hover over the command it switches to alphabet M and stays like that dis regarding my position mapping settings. How can I address this issues?
In the preferences dialog under the ribbon section change the position mapped groups from pop-up to menu.
Answer Verified By: Phani Gubbala
That worked perfectly.
Thank you!
