How is the cross sections spacing controlled for the first section placed on a sheet. I see all the configuration variables for side spacing, top and bottom as well as distance between cross sections. But there seems to be no way to indicate the starting point and exact spacing the cross sections they seem to float around a bit within the general area of the sheet. I am getting the first image what I really want is something like the second image.
What software and version are you using?
For more information about the Road and Site design tools, visit the Road and Site design WIKI at:
http://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki
If you're using OpenRoads Designer, please look at the XS start seed and specifically where the referenced named boundary is placed in the sheet model. There's an example workflow on our LearnServer. Here's a link to the video. https://learn.bentley.com/app/VideoPlayer/LinkToIndividualCourse?LearningPathID=111346&CourseId=119812&MediaID=5012923
I am using OpenRoads Designer R3 U9 V10.09.00.91, I have seen the "Process" for setting up the cross section named bound location in the sheet model. But is seems to float around with regard to the initial positions. I have a specific locations where I would like the cross section corners to be, but moving the referenced name boundary to that locations does not directly result in positioning the first cross section in the sheet at that location.
Mike LongstreetVermont Agency of TransportationCivil Engineering Technical SupportVTCAD Help
