Superelevation lost when repocessing corridor
Hello, when I reprocess my corridor, the superelevation definition disappears. I've defined my superelevation in other file, then I've referenced it into my model file and I've assigned to my corridor. So far everything is correct, but when I reprocess the corridor the superelevation definition disappears. I've detached the file with superelevation definition and attached again but there's no way to define the corridor with superelevation again.
I attach two screenshots, one before reprocessing wtih xsections with correct superelevation,
and other one after with xsections without superelevation.
Does anybody experienced something like this?
Thanks!
  • This is not necessarily true. The recommendation is to create a separate superelevation file and should work as intended. Some common issues with superelevation detaching from the corridor are:
    • Horizontal alignment updates; superelevation file not reprocessed after these adjustments (open and close file).
    • Horizontal alignment deleted/renamed; superelevation file not updated (as Krysztof mentioned above).
    Jennifer Perry
    Highway Design | Johnson, Mirmiran & Thompson, Inc.
