When exporting ORD profiles to autocad deg format, all annotations are showing 0 % values
Rgds
Venkat
Not enough information in this post... You need to always state what version of ORD you are using... The early versions were quite bad at exporting a profile to DWG format. So I suspect this may be the case here that you are using an old version. The current version 2020 Release 3 update 9 works fine for me.
Ross
Ross Brown
ORD version 2019 release 1
venkat
That is quite an old version now and I would recommend you update to the latest version. Refer post below from Mark he has done some fantastic work for the ORD community in documenting the dwg export changes at each release. Update 9 seems to be the best so far.
https://communities.bentley.com/products/road___site_design/f/geopak-inroads-mx-openroads-forum/169182/ord-dwg-export-workflows
